2003 replacement radiator.
Old Aug 11, 2018 | 04:19 PM
2003ElectronBlue's Avatar
2003ElectronBlue
3rd Gear
Default 2003 replacement radiator.
I need to replace the radiator in my 2003 automatic corvette. I cannot find the correct replacement anywhere and was hoping someone on here could help me locate one. Mine has the larger inverted flange. I can find the small inverted and the quick release. I just want an oem radiator with the larger flange or some easy adapter.
Can someone please lead me in the right direction?
Old Aug 12, 2018 | 09:23 PM
redzg's Avatar
redzg
Any chance you've removed the quick disconnects, exposing the 18x1.5 metric threads?
Old Aug 12, 2018 | 09:47 PM
2003ElectronBlue
3rd Gear
No I don't believe so. Both lines that screw into it look original.
Old Aug 22, 2018 | 10:03 PM
redzg's Avatar
redzg
Did you figure out a solution?
Old Aug 22, 2018 | 10:12 PM
2003ElectronBlue
3rd Gear
I did. I ordered the correct one from a radiator shop. Knew exactly what I was talking about.
Fixed and up and running.
Thanks for asking
To 2003 replacement radiator.
