Anyone have information on how to install a 4.10 rear end assembly. I have one dealership telling me 4 hours and a "supposedly more experienced" dealer telling me 8 hours. The more experienced dealer tells me that the rear end has to be re-aligned. Does the computer need reprogramming? Thanks for any assistance - Lost in Tampa.
Re: C5 4.10 Rear End Installation Instructions??? (EditMan)
I can install the rear in about 3 hours. Its pretty easy and straight forward.
1) drain fluids
2) remove rear wheels
3) drop H or X pipe
4) drop rear mufflers
5) unhook shocks, e brake cable, tie rods
6) drop rear crossmember while supporting tranny
7) lower tranny to reference point
8) remove and install new rear carrier
9) reinstall is reverse from removal
Phillip
4 hours, if that shop will agree to let you pay for just 4 hours labor go with them! It should take 4 hours taking their time but if you're good like Phil and I, it'd be 3 ;). No reprogramming is needed on an MN6.
Re: C5 4.10 Rear End Installation Instructions??? (C5Noir)
1) drain fluids
3) drop H or X pipe
Phil... you make it seem so easy!!! :)
on my web page is a link to an excellent step-by-step article about doing just that. They go as far as removing the torque-tube from the rear of the engine... but if its just the carrier; then you don't even need to do that.
Hey C5Noir,
Not that I'm an expert but I would think with your setup, you should be in the 11's ET. (esp with 125 NO2) - What kind of tires were you racing with? BTW - How did you like the 4.10 mod?
Re: C5 4.10 Rear End Installation Instructions??? (Mike Mercury)
1) drain fluids
3) drop H or X pipe
Thanks Mike for the info... I have one shop here locally that allows me to watch and assist... (since there are some instructions now, I might have them do the work.)
Hey C5Noir,
I haven't been to the track to drive it myself (the time in my sig was by my brother, has on experience with the C5 ;) ) since the 4.10s but yes my MPH clearly indicates I can run 11s. I'm going this Friday to try to muster an 11 second pass. However, I run ONLY street tires Nitto 555 Extremes (NOT DRAG RADIALS). I keep stock air pressure etc that way I know what I can do on the street. Sticky tires = 11's with ease. Street tires and 11's, gonna take some hella driving, I'll try for ya'll on Friday though ;)
