Coolant temp gauge maxes out on cold start up?
Old Aug 18, 2018 | 06:56 PM
Hoonigan628's Avatar
Hoonigan628
Cruising
Default Coolant temp gauge maxes out on cold start up?
01' C5 . So I just finished changing all my spark plugs, go to test run it, start it up and the temp gauge goes directly to 260, so I know the engine clearly isn't hot and sounds fine, but wtf, could I have bumped something, sensor maybe, where do I look, I tried the old unplug the battery and plug it back in method but no dice. Same shut in start up.. Anyone else has this
? And figure it out?
Old Aug 18, 2018 | 07:27 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Your engine temp sensor is the likely culprit and in full on ground mode with no resistance variance.You may get lucky and find that your connection is loose or needs freshening.
Swap the sensor and I bet you will be good.
Old Aug 18, 2018 | 07:36 PM
Hoonigan628
Cruising
An yep son of a B, I broke it , just checked, must have broke it when the dang plug let loose an smashed my knuckles against the alternator. Oh its been a fun day... Thanks
To Coolant temp gauge maxes out on cold start up?
