Has anyone broken 13s stock?
Oct 23, 2002 | 05:43 PM
With a MN6 coupe with run craps?
If so, what was your technique.
I want to make a couple stock passes before mod madness takes over.
Oct 23, 2002 | 06:15 PM
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Re: Has anyone broken 13s stock? (msuc5vette)
Roll off gently, as if you were leaving from a stop sign, then mash the throttle. If you try to leave at anything higher than 1000RPM, you'll sit and spin. Practice, practice, practice.
I think my best run was around 13.5 or 13.4 with the stock F1 EMTs.
Oct 23, 2002 | 06:36 PM
You should have no problem getting into the 13's. 2001 Coupe A-4 best 13.44 ET at 105.55 MPH totally stock on runflats. Torque the auto on the start then nail it and hold on.
Oct 23, 2002 | 06:55 PM
I did not have any times with the car totally stock. I did run several 13.0X @ 109 with just an intake (MTI) on runflats. I have an '01 6 SPD. I suspect I could have gotten 12.9X if I had not shifted to 4th before I went through the traps.
[Modified by R6_C5_ML430, 4:56 PM 10/23/2002]
Oct 23, 2002 | 07:03 PM
Re: Has anyone broken 13s stock? (R6_C5_ML430)
c5 pig went 12.7 when his car was stock
Oct 23, 2002 | 07:08 PM
CA Events Coordinator
Honestly, my first pass down the 1/4 mile was a 13.7 @ 105. The car was totally stock at the time. :yesnod:
vetterdstr :cheers:
Oct 23, 2002 | 07:24 PM
Re: Has anyone broken 13s stock? (vetterdstr)
First track appearance, stock 2000C5, ran a 13.5 with a 2.2 60'
Oct 23, 2002 | 07:32 PM
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Re: Has anyone broken 13s stock? (robsvette)
:eek: :eek: Stock??!!
Oct 23, 2002 | 07:33 PM
I ran 13.02 with Runcraps...They are a real disability!! :yesnod:
Oct 23, 2002 | 07:40 PM
Re: Has anyone broken 13s stock? (vstella)
i ran 12.829 @ 111.39 my first time out. I did remove the MAS screen and airbox cover before that run though...309 and 320 Rw. But, only got a 2.131 60' time...best with EMTs was 1.91. This run was made with a 1500 Rpm clutch dump off of the line.
The best method I found is to slip the clutch out from a rev of 2800-3500. As it comes up the gas pedal goes down respectively, gradually and smoothly. This made the car come out without spinning or bogging.
:cheers:
Oct 23, 2002 | 07:55 PM
Re: Has anyone broken 13s stock? (C5Cemo)
I ran 12.77 at 111 with runflats. I did have B&B PRT's and a Vortex cold air. My dyno's rwhp was 315 (up from 302 stock)
Oct 23, 2002 | 09:42 PM
From: Buy USA products! Check the label! Employ Americans
Re: Has anyone broken 13s stock? (jschindler)
Ran 13.01 @ 108.?? when it was 100% totally stock 18 lb. in tires launch at 2500 I don't have much practice. dyno was 310/309 totally stock :seeya
Oct 23, 2002 | 11:04 PM
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
Re: Has anyone broken 13s stock? (jreed99)
Quote:
c5 pig went 12.7 when his car was stock :eek: :eek: Stock??!!
Not hard to swallow since my stock LT1 went 12.9
Oct 23, 2002 | 11:09 PM
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Re: Has anyone broken 13s stock? (Mr Mojo)
Yea but with who driving ??? :lol: :lol: :lol:
Oct 23, 2002 | 11:32 PM
Man, I have GOT to get my C5 to the track (I've only had it for 3 weeks). :D
Oct 24, 2002 | 12:02 AM
Re: Has anyone broken 13s stock? (CHRIS NJ C5)
Wasn't you, that's for sure! :lol: :lol: :lol:
Hey, clean your email inbox out dude.
Oct 24, 2002 | 12:09 AM
12.9 bone stock
Oct 24, 2002 | 02:55 AM
Re: Has anyone broken 13s stock? (Wide Open Throttle)
Wow, WOT, you run 11:9 with only the mods in your sig?
I believe it. I will be going to the track pretty soon and can drive great. I'm thinking 12:3 without the Predator on EMT's and 11's with the Pred and DR's
