Gauge Backlights Flickering on/off
Old Oct 23, 2002 | 06:11 PM
cmacleod's Avatar
cmacleod
Default Gauge Backlights Flickering on/off
Does anyone have any problem with their backlights on their gauges flickering on and off every once and awhile? Mine does it a couple times a week. I loose the backlights on everything in the car and then it comes back on a second or two later. It is not a big deal but I was wondering if I am the only one that has this problem. :eek:
Old Oct 23, 2002 | 06:48 PM
dm3557's Avatar
dm3557
Default Re: Gauge Backlights Flickering on/off (cmacleod)
I have the exact thing all the time. I assume it has some sort of light sensor getting some direct light from a street light causing it to dim...but I'm just speculating...
Old Oct 23, 2002 | 07:04 PM
cmacleod's Avatar
cmacleod
Default Re: Gauge Backlights Flickering on/off (dm3557)
Well at least I am not the only one. Hopefully some other form members have some ideas.
Old Oct 24, 2002 | 02:49 AM
SoCal C5's Avatar
SoCal C5
Kinda sounds like a loose wire or bad ground. Does it seem to be related to bumps in the road. If so I would strongly suspect a lose connection or ground
Old Oct 24, 2002 | 10:15 AM
hemmerman's Avatar
hemmerman
I have a similar problem. I notice while driving at night it seems like the fog lights flicker just once in a while. kind of wierd. I'm sure if it is effecting any other lights (tailights) I'm going to talk to the dealreship about it maybe they can shed so light on this problem. Hemmerman
Old Oct 24, 2002 | 11:33 AM
cmacleod's Avatar
cmacleod
Default Re: Gauge Backlights Flickering on/off (hemmerman)
Great,
Let me know if you learn anything. It does not act like a grounding problem. You can just be driving along and the system will do it for no apparent reason. When I bought the car initially, the system had a popping noise in the stereo system. I brought it back in and the dealership brought in one of GM’s engineers and he spent two weeks figuring out it was two wires wrapped around each other in the wiring harness that should not have been wrapped together. This was causing the interference in the radio.
Therefore, I would be very interested if you come up with anything. :crazy:
[Modified by cmacleod, 9:34 AM 10/24/2002]
To Gauge Backlights Flickering on/off
