Sway bar links
Old Oct 23, 2002 | 06:42 PM
Z07 Ed's Avatar
Z07 Ed
Default Sway bar links
Is there a noticable advantage in changing out the plastic sway bar links with the newer G.M. metal links that are on the 02&03 cars. Thanks
Old Oct 23, 2002 | 11:32 PM
alc2001's Avatar
alc2001
Default Re: Sway bar links (Ed Merchut)
I changed mine when I swapped out my base suspension sway bars for Z06 bars. They are definitely stronger but I am not sure that would be of much value unless you are autcrossing. They are better looking and only cost about 15$ each, so I just did it.
Old Oct 24, 2002 | 12:11 AM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Default Re: Sway bar links (alc2001)
Are you sure that you have those end links on right? If that's a pic of the front bar, they look like they are touching the steering bar. When I removed my front Z51 end links and installed the new bar links the bottom nut on the front bar was pointing out with the nut on the front of the lower tab and the top end link nut was pointing in towards the shock with the nut rearward of the swaybar. :confused:
Old Oct 24, 2002 | 12:48 AM
alc2001's Avatar
alc2001
Default Re: Sway bar links (xtream1)
Paul,
Don't scare me like that! :eek: Actually this is the rear and I just checked the service manual and it's ok. Whew. When I was putting the front on, I did hook up the first side backwards before I caught myself. :seeya
Alan
Old Oct 24, 2002 | 04:35 PM
TLewis4095's Avatar
TLewis4095
This photo shows why the plastic links are junk, and if in a hard manuver situation on the road down-right dangerous. The plastic ones will buckle and fold (see how these look like they are misshappen?) causeing a violent side to side swaying that perpetuates itself until they hold again so the sway bar can do it's job.
It happened to me twice while passing and haveing to turn quicker than I expected....and took a bit of examining to figure out what happened. It appears that under a heavy cornering load when it folds it unloads and then as you bounce back the other way it folds that link, and vice/versa.
Metal links prevents that!
Bear in mind that I do NOT have AH, only traction control. :cheers:
Old Oct 24, 2002 | 05:11 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Re: Sway bar links (TLewis4095)
I don't know where GM got the idea to put plastic end-links on these cars but I personally wouldn't trust them if I was doing any hard cornering. I guess they had to save like 50 cents a peice to mold them out of plastic. We offer the Heim end-link set for $139.95 which will increase the affectiveness of the sway-bars if your interested. :seeya
Old Oct 24, 2002 | 11:31 PM
TLewis4095's Avatar
TLewis4095
Default Re: Sway bar links (MANNY)
....This photo shows why the plastic links are junk...
TLewis4095, I only see x. Twice.
Sorry Manny, I tried to copy the top pictures....they show how the plastic links warpped and misshapped. :cheers:
Old Oct 24, 2002 | 11:41 PM
johnnyC5's Avatar
johnnyC5
mine busted today..... :nonod: :sad:
Old Oct 25, 2002 | 02:09 PM
MySea6's Avatar
MySea6
Not unless he figured out a way to mount the rear shocks on the front. :lol:
The new style alloy or heim joint endlinks are the best solution IMO. :cheers:
To Sway bar links
