Using my buddy’s lift👍
ended up using Redline gear lube (almost two quarts) and a little more then four quarts of trans fluid! Felt weird firing up the car to pump more fluid into it. Anyways the fluid was not taken care of from the previous owner, so I’ll be back under there to pull the plug not running and top her off again! Is there a better way to flush the trans? Let me know if there is, thanks cruzbox 👍
