my rear diff fill plug cannot be removed. It appears to be welded shut by corrosion or something. I have tried every trick I know to get that rat bastard out. It's been hacked at before, and unsuccessfully at that - the hex head is badly rounded. I m trying a 10mm and an 24" breaker and I can't make it stay in the hole.
When the fluid drained it was pure milkshake - don't think it has ever been changed. The bottom plug was brutally hard to get out as well, but broke loose.
I have no idea how I'm get this problem fixed. Has this ever happened you before?
Next time, always take the fill plug out first. That's related to anything really. When I have a drain or fill plug stuck at work, I use an air hammer with a chisel bit. Very carefully of course.
I have air tools, and will jam a thin piece of metal into the plug to make the Allen fit tightly. Then I'll hit it with the big 300 lb-ft air hammer. I soaked it in aerokroil last night.
it almost can't be made worse at this point, so anything is an improvement.
Hold up on hitting it with the 300 LB hammer!
here is a tip that may help,
Visually inspect our hex tool for any damage or roundness, is your hex tool is not in perfect shape, replace it before the next step.
Run down to your local auto parts store and get a tube of Permatex Valve Grinding Compound (1.5 oz).
Thoroughly clean your NEW hex tool and diff plug with brake cleaner to remove any oil contamination.
The valve grinding compound contains sharp abrasives which should aid in the hex tool getting a bite on the diff plug.
Apply the valve grinding compound to the end of the hex tool and the hex in the diff plug.
Ensure the that your tool is not "rolling out" of the plug during the turning of the tool, you will need to use pressure on the tool while rotating to tool.
hope this helps,
Cheers
Goose
If the valve grinding compound trick does not work, find a set of these extractors and these should do the job . Try to find the best size extractor the will get a bite BEFORE you drill the plug...
These extractors are made by Neiko
Neiko 04204A Hex Head Multi-Spline Screw and Bolt Extractor Set
I've decided that my leverage is too poor, my tool set too inadequate, my experience is too limited and my patience too marginal for a successful outcome. I am taking it to a professional. Having the car towed now.
I have to say, that _________-_______ is stuck on like Thanos' glove.
The professional has worked his bloody-minded magic and gotten my fill plug out. They are welding a nut to the outside and replacing it. $90 and change.
