electrochromic rearview mirror does not work
Old Aug 26, 2018 | 01:30 PM
LarryGChapman's Avatar
LarryGChapman
3rd Gear
Default electrochromic rearview mirror does not work
2002 zo6
Old Aug 26, 2018 | 01:44 PM
Tsumi's Avatar
Tsumi
Is the green light in the mirror on? If not, check fuse 2 in the passenger footwell fuse box.
Old Aug 26, 2018 | 01:57 PM
LarryGChapman
3rd Gear
It was fuse 2. I initially went to fuse 21 as that is the fuse listed for the rearview mirror but it was good. Replaced fuse 2 and works fine now. Thanks for your help.
Old Aug 26, 2018 | 01:59 PM
LarryGChapman
3rd Gear
Originally Posted by 8VETTE7
Have you verified fuse #21 in the passenger foot well fuse box is good? Also Splice Pack SP202 and ground G202 located at the bottom of the right A-Pillar behind the decorative trim.
Fuse 21 was good. Fuse 2 was bad.. Replaced and now works fine. Thanks
Old Aug 26, 2018 | 02:01 PM
Tsumi's Avatar
Tsumi
Yep, it's a bit confusing as both fuses supply power to the mirror, just different parts of it.
To electrochromic rearview mirror does not work
