power steering mounting bolt broke
Old Aug 26, 2018 | 05:15 PM
99blue frc's Avatar
99blue frc
Default power steering mounting bolt broke
I was removing the ps cooler in order to do the harmonic balancer and seal replacement and the bolt on the passenger side broke. I drilled thtie center of the bolt and inserted the extractor. Then slowly was tightening up on the extractor and it broke!! Now my question is, can I tweek the mounting flange a little bit and drill and tap a new hole.
Old Aug 27, 2018 | 12:54 PM
TastyBacon's Avatar
TastyBacon
I think the best solution would be to drill the whole thing out and helicoil it, but that may be more trouble than it's worth for a bolt that's under very low stress, and nobody really sees or cares too much about. M6 helicoils can be a pain to work with anyway.
If you can bend the mounting tab enough to line it up with some fresh aluminum on the crossmember, drilling and tapping a new hole would work just fine. I made a custom bracket for a shorter power steering cooler to clear turbo intercooler pipes on my car and had no problem drilling new holes in the crossmember and tapping them to M6x1.0.
Good luck!
Old Aug 27, 2018 | 05:07 PM
99blue frc's Avatar
99blue frc
After I posted I thought to do just that. Now have to try to remove an 1/8 extractor ! This could be interesting not in a good way.
To power steering mounting bolt broke
