Just thought I'd share this. I have been dealing with a pretty loud valvetrain tick/tap on cold starts for awhile now that makes me cringe everytime I hear it. I have tried everything other than pulling the heads and visually inspecting to find out what the noise is. I used a stethoscope and finally narrowed it down to coming from cylinder 3. Anyway I was going to be doing an oil change soon so I said what the hell and bought a bottle of seafoam, I used to put it in my Trans Am and never had any issues. I put about 6oz in the crankcase and maybe 4 or 5oz in the gas tank, took the car out and ran it pretty hard. I have only cranked the car twice since doing this but both times the lifter noise is significantly quieter. I can still hear a little bit of lifter noise but nothing I wouldn't consider normal. The obnoxiously loud tap seems to be gone and it was present every single time I cranked it on a cold motor. I would assume that if I actually had a damaged lifter roller or bad cam lobe then the noise wouldn't have gone away just by putting a cleaner in there. Crossing my fingers that I had a gummed up lifter and it has free'd up. Also I didn't have any smoke at all from the exhaust after using the seafoam so I must have a pretty clean motor!
to really help clean the combustion chambers you need to run seafoam through the intake via a vacuum hose, doing it that way will create a lot of smoke if the chambers have carbon buildup in them... you can also use atf in the crankcase to help clean it... put a quart in with the oil and run it for a few hundred miles before your next oil change and the detergents in the atf will help break down sludge buildup... on a properly maintained engine you shouldn't have to do that though, regular oil changes will prevent that from happening
When I bought the car I did the full seafoam treatment, sucking some up in a vaccum line, and there was little to no smoke. I never go over 3k between oil changes but my car has done alot of sitting over the past few years so I'm thinking a lifter was a little clogged. I will prob put some in a vaccum line before I change the oil again. I considered the atf also but went with seafoam instead.
if a lifters sticking,its in the oil system,,,,not the fuel system,
ive fixed sticky lifters by draining the eng oil,filling crankcase with 5qts atf fluid,letting eng run for 1/2-1 hr,draining oil and filter,putting fresh oil and filter on and driving car
So I've driven the car a bunch of times now with the same results. I can still hear that one lifter over the rest but it's not nearly as loud and goes away faster than before the seafoam. So why would it be quieter but not go away completely? Maybe the seafoam has thinned out the oil and it's getting oil up in there faster? Or possibly the plunger was clogged and has free'd up some but not completely. What do you guys think?
take the valve cover off the offending side and push down and up on the rocker arm of the lifter and see if it is very easy to do so. Hydraulic lifters use oil to pressurize them so if you can push down on the lifter with the rocker and its very easy to do, you have a bad lifter. look at the rocker arm to valve and see if its a little crooked or does not look like the rest of them, the visual may sometimes detect an issue as well.
Thanks for the info, but I have done all of this.... twice.
I just took a good set of lifters out of my 02 vert. If you wanna try that I can send you as many as you want.... Shipping is on you
I appreciate the offer. I'm not ready to pull the heads just yet but I may end up getting a cam not far down the road so I will prob go with ls7 lifters then. Thanks tho!
[2QUOTE=cuisinartvette;1597929710]Youll never get rid of it 100% Its just the way these engines are. Sometimes real loud, othertimes not much at all.
No magic fix in a can[/QUOTE]
Oh I know, and I'm okay with typical LS lifter noise but when I hear one consistantly clacking away much louder than the rest I get a little aggravated
