Need help strange noise
Old Sep 4, 2018 | 12:12 PM
brad6285's Avatar
brad6285
Default Need help strange noise
im hopiing someone can help me out with this noise let me explain. I was driving my 2003 ae vert on sunday. Almost at the end of the ride i started hearing this noise. It sounded like my drivers side front wheel was kicking up a rock which created a clunk almost under me. This happened about ten times till i put it away. I have lg long tube heads on it also. I looked underneath as good as possible but didnt notice anything hanging down. Could it be the damping shock system. I dont see any leaks from the shocks. I know this could get expensive so any help is appreciated. Thanx brad
Old Sep 4, 2018 | 12:20 PM
Smoken1's Avatar
Smoken1
Check your sway bar end links. Mine made noises like that
Old Sep 4, 2018 | 01:50 PM
brad6285's Avatar
brad6285
Default Clunk
Thanx its the rear just took it to my mechanic took it for a ride his first words was suspension. Years ago i changed the front and rear sway bars with z06 ones with neoprene bushings so i had the links off and maybe theyr loose or the swaybar is loose. He didnt have time today to go over it but im going next week ill have him torque everything down. Thanx for the responce. Brad
Old Sep 4, 2018 | 02:48 PM
Moved to C5 Tech.
To Need help strange noise
