I used the H12/H11 bulbs.. You just have to modify the the "ear" on the bulb itself.. It 's plug just like oem other than that.
I just couldn't justify $500+ for something I don't drive at night a bunch...
But the reviews on the radioflyer set ups are very positive.
I'm the same... rarely drive in the dark, so can't (and/or won't) justify loads of money. Do these bulbs cause issues with oncoming traffic, or is that another type? Which number is the low beam (I literally never drive in the dark where high beams are needed).
No other mods , other then the ear on the bulb? Is it a bright white light or does it have a bluish tint?
We have a fair numbers of times that we end up driving at night when returning from different shows/meets/get togethers, etc. I tried MostPlus HIR 9012/9011 and they were an improvement but finally switched over to the RadioFlyer lights and there is a night and day difference (pun intended ).
I also considered the JW Motorsports ACA set up, but to their credit, they were very upfront and advised me their high beams could not be aligned. For the most part, probably no biggie since the upgraded low beams are good by themselves, but we're covered with mountains and some nice twisty roads to the North and West of us and being able to have the high and low beams (using the Hi4 harness) on at the same time really brightens things up on those roads.
honestly, probably a $20 eBay HID kit i've seen a few guys on here recommend as a decent set & the beamtech LEDs with the passive heat sinks.
but these are a good ways down the list of junk to get did... and i mean WAY down, so don't expect any reviews soon. i did do one on a $10 LED fog option i tried out a few weeks ago, though.
None of which can even compare to Radioflyer, and some of which are downright dangerous to yourself and other drivers.
haha... as soon as i saw you replied, i knew exactly what'd be there when i opened it.
i never said it'd be comparable or in any way related to a full-on HID retrofit, however, in my research, i'll definitely ensure where the focal point of the lamps are in relation to the stock halogens - which, as a fellow lighting engineer, i know you can understand mitigates some of the glare & beam scatter because it's being focused at the same point as the previous light source. on top of that, i know how to properly adjust and aim them. don't worry!
Not possible in the case of HIDs. The HID arc and the halogen filament are in completely different orientations. Closest possible are LEDs, which I have yet to see definitively puts out more light than halogens. Whiter, yes, but not necessarily brighter.
out of curiosity, do you mind clarifying your orientation statement?
HIDs have the contacts arc in a plane parallel to the glass protrusion from the base (for lack of better descriptors), and the H9 halogen (9006/5, too, for that matter) have the filament strung in a likewise manner
not the best picture, but it's quick & shows an example of each
for focus, the important factor is making sure the xenon arc is centered at the same distance from the base as the filament. same goes with judging LEDs.
as for power, some of the newer design LEDs have managed to produce outputs rivaling HIRs or better.
