Reduced power
Old Sep 5, 2018 | 08:00 PM
BRKLYN's Avatar
BRKLYN
Default Reduced power
Code P1221, SCARED ME something awful, I only cruise this car for twelve years now. I see different post, saying its tps and others gas pedal sensor??? I know there’s a lot of guys here that had that happen to them. How hard a replacement TPS? Runs fine now, cleared the codes. Should I change air filter first? Questions questions question, a lot of great info here thank you.
Old Sep 5, 2018 | 08:09 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
P1221 is a TPS correlation issue...what does changing an air filter have to do with TPS ???...confused ???
Old Sep 5, 2018 | 09:08 PM
BRKLYN's Avatar
BRKLYN
I saw/ read where an individual had reduced power and changed his filter and that was it.
Old Sep 5, 2018 | 09:15 PM
C5 Diag's Avatar
C5 Diag
Oh, OK !!...change the air filter and let us know if the CEL goes out after the 3rd trip and it has passed !!
Old Sep 6, 2018 | 07:46 PM
BRKLYN's Avatar
BRKLYN
Is there something i should be careful with, when removing the old throttle sensor? I,m off to the Caribbean, i will get to it end of the month. Thanks!
To Reduced power
