Help Telescopic function of steering wheel stopped working !!!
Old Oct 24, 2002 | 05:56 PM
newbie's Avatar
newbie
Default Help Telescopic function of steering wheel stopped working !!!
Has this happed to anyone? Did a search again "telescopic" and got emtpy results. Anyone know hot to fix without having to visit the shop ???
Luis
Old Oct 24, 2002 | 06:02 PM
jojog's Avatar
jojog
Default Re: Help Telescopic function of steering wheel stopped working !!! (newbie)
I understand you can do a reset / relearn by pressing the control switch 6 times in either direction. Worth a try!
Old Oct 24, 2002 | 06:40 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Help Telescopic function of steering wheel stopped working !!! (jojog)
correct. :yesnod:
Old Oct 25, 2002 | 09:16 AM
newbie's Avatar
newbie
Default Re: Help Telescopic function of steering wheel stopped working !!! (kewlbrz)
I did the "press button eihter direction 5/6 times" last night and nothin, now this morning It is working, WTF. Other than the Engine and the looks did GM do anything else right on the C5 ?????:( :mad
I'm hoping it stays working.... time to get an aftermarket warrantee
Old Oct 25, 2002 | 09:38 AM
jojog's Avatar
jojog
I don't know, but is it possible you have to "reboot" (turn car/power off and then back on) for the relearn to kick in??
Old Oct 25, 2002 | 11:31 AM
WildWolf's Avatar
WildWolf
I used to have this problem a few years ago and then the problem dissappeared- until the other day. What I do is just keep clicking the switch back and forth for about 5 or 6 minutes and eventually it starts working again. Good luck :cheers:
Old Oct 25, 2002 | 10:28 PM
01Pewter's Avatar
01Pewter
CI 2-3-4-5-6-7-8-9-10 Vet
CI-X Auto-X Champ (street tires)
Cruise-In IX AutoX Winner
The telescopic steering column is controlled by the memory seat module.
I am guessing that you have a loose connection between the column switch and the seat module. A defective column position sensor might also cause a problem. The shop manual has a procedure to determine the problem.
To Help Telescopic function of steering wheel stopped working !!!
