I bought my first Vette it’s a 2000 looks great runs great the problem is it has 174000 miles on it no knocks leaks or smoke has great oil pressure the car still has life in it. I want to do some mods eventually. Looking for simple advice on how to proceed. Should my ls1 have a fresh rebuild first?Thanks in advance.
A compression check would be my 1st thing to check. I would also change your valve springs to ensure you don't get valve float when running high RPM's with performance mods.
I believe it really depends on what mods you are talking about. If you are talking about more benign things such as a Cold Air Intake you should be fine. If you are talking about power adders such as, heads, cam, turbo or supercharger, you really should look into the overall condition of the engine. A well cared for and unabused LS1 should have no difficulty lasting 200k miles or more. The same would apply to the rest of the powertrain.
If you are not aware of how the car was used and cared for up to this point, the prudent thing would be to evaluate thoroughly what you are starting with. There are plenty of reputable shops, tuners that can give you a comprehensive evaluation of what you have.
Thank you I have had two mechanics I trust look at the car and say it is very sound and yes I’m thinking eventually can and headers and some other bolt ons not thinking sc. just looking to get some extra hp to make it more fun.
Several years ago GM took one of their engineers DD 2002Z at 216000 miles and spent almost a week tearing the engine apart and inspecting everything for wear. Since he was an engineer, he religiously changed his oil an filter, everything used was Mobil1. They were amazed at how little wear the engine had experienced and the sodium filled valves were is remarkable shape and even the valve springs were in good condition. Now this car was driven summer, fall, winter, and spring. It ran numerous HPDE's and was heavily autocrossed. They figured the answer was in the maintenance the owner had given the Corvette. That car is still running strong today with about 270,000 on the clock.
Honestly I'm of the logic where if it ain't broke don't fix it. If your mods don't foresee boost then I don't see a reason to go through a rebuild. Bolt ons are easily transferred/handled/left when dealing with either a rebuilt or new long block.
When I purchased my 2001 coupe it had a very significant oil leak. It was leaking at the rear of the oil pan on both left and right sides. The PO had had the oil pan gasket replaced 3 times with the leak still there after all 3 repairs. I decided to pull the engine to repair the leak due to the above attempts at repair. I then tore the engine apart and found the problem was with the upper oil pan not being flat across the back.
It was one of those well while it is apart I will replace this and that situations. The car had 144000 miles on it. Everything in the motor looked like brand new except a couple of minor items.
I am sure that the motor would have ran well past 200000 miles if I had not done anything but fixed the oil leak.
If it has the 2 piece batwing pan, have your mechanic remove the lower portion. Can be very revealing about past maintenance.
Ron
You can also pull the intake and valley cover to see how black the valley is.
As mentioned above, I'd do a compression test. You can do an oil analysis. If they come back clean, keep running it. What is your goal? A decently maintained LS will drive a long time.
Just acquired 2001 from a family member, it has 238,000 miles on it. He had some transmission work and a clutch around 60,000 miles. Most of them between Ga. and Fl. It drives tight, clutch feels good, still shifts great. Pulls hard to redline. This is my tenth corvette since 1974. Enjoy it
My 2003 Z06 has 164,000 miles on it. It still drives as good as new. Starts perfectly, runs cool and uses no oil between changes at 40-50% on the DIC. It's done its share at Englishtown drag strip, does some road course work and run close to top speed several times. I still love my car and have no intentions of getting rid of it anytime soon. Still modding it, too. Use it and beat the hell of it as you'd like. It can take it. These cars run great even with lots of miles on them. A C5 was recently donated to the NCM with around 700,000 miles on it and still running fine. BTW, the most major repair my car has had is a bad slave cylinder led to a clutch change at 106,000 miles.
