Sticky drivers side PopUp Headlight
Old Sep 15, 2018 | 11:30 AM
clinck's Avatar
clinck
1st Gear
Default Sticky drivers side PopUp Headlight
I don't drive the car much a night. In fact, I haven't driven the car at night for over a year. My driver's side Pop up wont Pop up.. The passenger side is fine but nothing happens on the driver's side. When I retract the headlights, I get a gear grinding sound from the lamp that did not extend. any thoughts?
Old Sep 15, 2018 | 11:56 AM
runner140*'s Avatar
runner140*
You have to rebuild your lazy bucket side. It has a plastic/composit gear that is worn down and needs to be replaced. Replace with a brass gear and you will be set. Get the rebuild kit from rodneydickman dot com. The kit comes complete with the T brace, the brass gear, glue, shims and great instructions.
Old Sep 15, 2018 | 01:01 PM
JR-01's Avatar
JR-01
Or if you want to just bolt in a rebuilt replacement motor, Amazon has them for about a hundred bucks.
Old Sep 15, 2018 | 02:33 PM
rrwirsi's Avatar
rrwirsi
Then rebuild the one you take out so you will be ready for install when the other one to fails which surely will.
Old Sep 15, 2018 | 03:44 PM
JR-01's Avatar
JR-01
My original 17 year old units are over 80K miles without a problem. If the rebuilt unit lasts that long I would be happy.
From the description of bebuilt unit:
A1 Cardone Remanufactured Headlamp Motors are engineered and remanufactured to meet or exceed OEM performance. Original design weaknesses are corrected to make a longer lasting product. Cardone engineers use the latest in technology and innovation to create high value at a low cost, providing a quality product both you and your vehicle can rely on.
Old Sep 15, 2018 | 08:36 PM
Moved to C5 Tech.
To Sticky drivers side PopUp Headlight
