A/C Problem?
Old Sep 15, 2018 | 08:27 PM
Torchvette02's Avatar
Torchvette02
1st Gear
Default A/C Problem?
My compressor clutch recently stopped coming on, I jumpered it out and it is working. I also checked the fuses and the relays, and It does not show any codes. I think it might be the refrigerant pressure sensor. My question is does the refrigerant have to be removed from the system to change this switch or does it have a schrader valve that keep it in?
Old Sep 15, 2018 | 09:14 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
unfortunately it does need purged to make that change.
Old Sep 15, 2018 | 09:28 PM
redzg's Avatar
redzg
Not to be an ***, but you are sure the pressure is adequate?
Old Sep 15, 2018 | 10:23 PM
GCG's Avatar
GCG
Before taking drastic steps, get a set of gauges and check the system static pressure first and, if it's safe, jump again the low pressure switch to read both the low and high pressures. Perhaps the switch is fine and it's that there's not enough refrigerant in the system.
Old Sep 16, 2018 | 05:14 PM
old stingray's Avatar
old stingray
I agree with redzg and GCG check your pressure.
To A/C Problem?
