Rear brake hard line
Second question is replacement part. I can't find the part still available, so I assume I get to buy a straight line and bend it myself (avoiding the axle this time!). The wheel end appears to be a bubble flare. Is the tunnel end the same? Will the best choice be a Poly Armour PA-760? It's 6mm (catalog says some GM) with bubble flares on both ends. Was originally looking at 3/16 lines but not sure now.
Thanks in advance, Rick
To get to the top connections disconnect the driver side tailpipe from the mid pipe and move it out of the way. Now you have room to move.
I crawled in from the passenger side. I know the lines are on the driver's side but you can't get your arms up there in such a short space.
You need to make or buy a 13mm flare nut wrench. It's a box wrench with part of the "box" cut out so you can slip it over the line. The flare nut wrench can be jammed against the tunnel or transmission and will hold the one side of the connection by itself. You can work the other side with a 13mm open end wrench one flat at a time.
I bought 3/16" Copper/Nickel line and made my own flares. They are all the same except one of the top ones which needs to be flared back on itself. The side that fits into it is the normal flare. These are ISO/Din bubble flares. Use the flat side of your anvil not the side with the flare. Just be sure yours look just like the ones on the line you take off.
What a pain in the a$$ fitting the line back in and connecting all the holders. I'll burn the car before I do this job again.
Good luck.
The other big problem with used brake lines is shipping. These lines are in a vaguely U shape about 2 foot across the ends and 2 foot sideways. Try getting that through UPS/Fedex/USPS cheaply and intact. One kink and you get to start over again.
The lines are 50" and 54" (L and R) in length. If the left went, the right will follow. Cop/Nickel is the easiest to bend and flare and it's impervious to corrosion but it doesn't come pre-bent.
Also on the C5 make sure the clamps are in place on the top of the rear subframe cross member that keep the hards hard lines anchored. Typically reinstalling the clamps can get overlooked during say a clutch replacement job. If the hard lines are not anchored they will be left to flop around (you will be amazed with the amount of movement if they are not anchored) and can hub against all sorts of stuff back under there and leaks can result as noted by the OP. If the clamps are missing on your car, you can use rubber dipped/coated Adel clamps as replacements along with the correct size and length small bolts and nyloc nuts - ask me how I know that trick. Also there have been more than a couple cases of the loose rear hard lines getting wrapped around the axles at the track events resulting in wreaks that were "not pretty".
