P0172 & P0175 codes.....again.
Old Sep 16, 2018 | 10:28 PM
Gunnmetalblue's Avatar
Gunnmetalblue
Default P0172 & P0175 codes.....again.
Hello forum. Just wondering if a problem with the fuel tanks. i.e. the dreaded crossover pipe leaking issue that I am dealing with on my 2001 coupe, would cause the P0172 and P0175 codes to keep coming up. I have no vacuum leaks, the MAF is new, and my BBK CAI filter is clean without excess filter oil. I also have started to hear the fuel pump cycling when I turn the key to the 'on' position.Thoughts?
Old Sep 17, 2018 | 01:06 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Leaking pipe would not be related to your DTC’s...172/175 are “rich” codes and could be several things that can cause this...also normal for the fuel pump to turn on for 2 seconds when the key is turned on !!
Old Sep 17, 2018 | 02:24 AM
Gunnmetalblue
The fuel pump making noise is a new thing, starting a few weeks ago after having the car for 4 years.
Old Sep 17, 2018 | 06:04 AM
C5 Diag's Avatar
C5 Diag
Possible the fuel pump is on its way out...Lean codes (P0171/P0174) are indicative of a failing pump at higher loads/RPM !!
To P0172 & P0175 codes.....again.
