Compression test.....
Old Oct 25, 2002 | 01:15 AM
Phil97SVT's Avatar
Phil97SVT
Default Compression test.....
What kind of results should I be getting when I complete my compression test? 175, 200, 225, 250?
Phillip
Old Oct 25, 2002 | 09:25 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Compression test..... (Phil97SVT)
What compression are you running? Stock motors seem to fall around 150-160 range. Is this on the high compression motor you just built. Make sure they are all within 10 lbs or so. :)
Old Oct 26, 2002 | 02:04 PM
Phil97SVT's Avatar
Phil97SVT
My compression is pretty flat across the board 205-215 per cylinder.
Phillip
To Compression test.....
