ABS/Traction Control Problems
Old Oct 25, 2002 | 05:11 PM
blumojo's Avatar
blumojo
Default ABS/Traction Control Problems
I have a 2002 coupe and lately I have been getting a service ABS/Traction Control light on the DIC. The car drives fine other than the bothersome warning light, any you can not put the vehicle in the competitive mode. I took the car in for service for this problem (3 days) to no avail. They have replace the wheel bearing which contains the sensor, they have replace the wire which leads from the sensor, and they have run test on the rest of the system and now they say that the transmission is sending/telling the computer that it is runing a different speed than the sensor, hence the problem code. Has anyone had this problem and what is the fix? Thanks
Old Oct 25, 2002 | 07:14 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: ABS/Traction Control Problems (blumojo)
What trouble codes are you actually seeing?
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Oct 26, 2002 | 05:03 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Sounds like they are grasping for straws, tell them to call GM Engineering Dept.
To ABS/Traction Control Problems
