P0133 code and rough idle after header and Blackwing install.
So, what are my options here? What could cause these issues? I will have to car on a lift tomorrow while they are welding and doing the bypass, so I should be able to check the connections and see if anything is loose or melted. I cleared the code, and it hasn't came back yet, although I only drove it around 10 miles since then. I have a Bluetooth OBD 2 connector and the Torque app on my phone, so I should be able to check the volts of the o2 sensors as well as see if it is running in open loop, I will go out and do that here shortly. I can also see LTFT and STFT and a few other things, but to be honest I have no idea what to look for or what is normal or not. I have no idea if it is running lean or rich, although I imagine if it is running in open loop it would probably fail safe to a rich state correct? Though not ideal, I should be ok to drive it around town short distances correct?
Any help or advice would be greatly appreciated... As I gather more information I will post updates.
Thanks in advance,
- Kevin
I'm a bit desperate for advice or help now...
Since you cleaned your MAF I’d make sure every connection to the TB is tight and leak free...I have a Black Wing too and never had any issues...if you can look at long and short fuel trims that would be great...write down your fuel trims at idle and 3000 RPM...if your long terms are positive (above 10%) and when you hold idle at 3000 RPM and the long terms start to decrease you have a vacuum leak...I’d look for any leaks upstream of the O2’s which can drive your long terms high. I’d probably get the tune before getting into the 0133...if you still have a “slow response” check your O2 voltage..with a “cold” O2 you should be reading the sensors “bias voltage”...450 Mv ...with the car running it’s best to “graph” the O2 instead of looking at the Mv !!...if it’s stuck at 450 you might have an open in the circuit...if you have a test light I can show you how to check circuit integrity while your looking at the Mv on a scan tool. A bad O2 heater circuit can also cause a slow response too...when the PCM checks the heater circuit it looks to see the O2 Mv decrease below 300 mv or an increase above 600 to check if the heater circuit is OK...if it stays between 300-600 Mv for a certain amount of time you’ll get a heater circuit DTC. Sometimes both DTC will set.
Thanks in advance,
- Kevin
Hey Kevin.
Give us a call any time. The symptoms you're having could possibly be electrical / mechanical but more likely just the routine stuff
that happens when you install an exhaust and intake.... Pretty common stuff.
Your tuning is a bit different than most mail order stuff as our tool allows us to check and re-check after each adjustment to make sure
nothing is left on the table and that you're safely making the best gains available for your mods.
Call any time at 914-332-0049
Chuck CoW
The car is in the shop now having some of the clamps removed and welded around to seal the leaks. The muffler bypass mod is being done as well. I'm still really worried about the car completely dying after hitting the rev limiter when missing a shift. I may end up making a new thread on this, as I do believe it is a totally different issue than the o2 sensor codes.
Keep us posted.
Chuck CoW
