Brake Master Cylinder Replacement Questions
Old Oct 8, 2018 | 09:53 AM
dale3guy's Avatar
dale3guy
Default Brake Master Cylinder Replacement Questions
I'm going to be replacing my master cylinder soon. Does anyone know what I can use to cap off the brake lines when I unscrew them from the master? I'm going to be replacing the brake booster too so I won't install the new master immediately after removing the old one.
Also, does anyone have a recommendation for a master cylinder bench bleeding kit that works well?
Lastly, any tips to not make a mess with brake fluid when I remove the bench bleeding kit and install the brake lines to the new master? Just go as quickly as I can with a towel underneath?
03 C5Z06.
