difficulty filling the gas tanks
I am having a lot of trouble filling my gas tanks. The auto shut off on the fuel dispensing nozzle just keeps on tripping. This happens at multiple pumps at multiple gas stations where my other cars work fine, so I'm pretty confident this is a problem with my car. Even pumping at the slowest rate causes the shut-off to trigger, and it does it continuously from both tanks near empty all the way until the tanks are actually full. Fuel does not appear to back up the filler hose/pipe.
The FSM has a list of possible causes for 'Poor Fuel Fill Quality' (as they call it), but I can't find an actual troubleshooting procedure. If I just knew exactly how everything in the evap system was routed I could probably come up with my own troubleshooting procedure, but I can only find a 'generic' evap schematic in the FSM (something that would apply to all cars, not the C5 specifically, page 6-503). If anyone knows where I can find a detailed, C5-specific fuel line and evap line/component schematic, that would help me a ton.
Possible causes as listed in the FSM include:
1. The check valve is stuck closed... I assume they mean the check valve in the filling pipe. I don't think this is my problem because fuel does not seem to back up and spit out as I fill. And I can dump fuel in from a gas can without any problem.
2. The fill limiter vent valve is stuck closed... could be my problem... does anyone know how to test for this?
3. The Evap canister is restricted... again, could be... does anyone know how to test for this?
4. The Evap canister vent solenoid is stuck closed... that was easy to check with the car on my lift, mine seems fine unless it only sticks when hot or something
5. Restricted EVAP pipes... again... anyone know how to test for this?
There are a couple of other things listed that seem unlikely to be the cause.
Any help/advice would be greatly appreciated... it would be nice to be able to fill my car faster than an electric car can recharge.
However, I did recently read that inserting the nozzle completely upside down might override the auto-shut off feature... I have not tried that yet.
What I end up doing is squeezing the nozzle as gently as possible with the nozzle inserted as little as possible into the filler opening on the car, and this will usually dispense a few cups of fuel before clicking off, then I repeat that many, many times. It takes forever.
The check valve is a float inside the tank, some have had them fail open, some have had them come apart, but I don't think I have heard of one stuck in the closed position. The only other option would be the vent valve failing closed.
And most of what you said makes sense to me just from my understanding of how an evap system and fill valve works, but what is the purpose of the line going from the check valve to the filler tube? Is that line attached to the tank side or the canister side of the check valve?
The line going to the fill valve connects just past the restricter the pump goes into. Here are some pics to help:
Fuel System Diagram
Fill Tube w/vent
Good luck!!
Just FYI...the EVAP system uses VERY LOW vacuum and pressure signals when it performs its onboard tests !!...1 psi max testing pressure as you can see here and around 1/4 psi or so vacuum !!...you don't want any more issues than you all ready have...like a damaged fuel tank pressure sensor !!
But I know on my car I can pour fuel in from a gas-can just fine, and fast... fuel is flowing into the tank, so I don't see how fuel can be backing up and covering that sense port on the nozzle.
So I researched some more, and many fuel stations have gone to a nozzle that has another shut off mechanism. If the nozzle is determined to be too horizontal they will shut off. The idea being that if the nozzle falls out of the car during refueling it would lay flat on the ground and this would shut it off. I'm thinking that's my problem, because the cure for this is to insert the nozzle upside down (so it is no-where near horizontal), and when I did that today, BINGO... worked fine.
First I inserted the nozzle the normal way and after it shut off about 6 times while only getting in about 3/4 of a gallon of fuel, I flipped the nozzle upside down and proceeded to fill the rest of the tank with only one shut off.. the one that should happen once the tank was full.
I think the nozzles near my house just don't like the angle of the refueling spout on a C5.
