PCM no comm
Old Oct 9, 2018 | 04:59 PM
new75coupe's Avatar
new75coupe
Default PCM no comm
Started getting all kinds of messages, service engine, active handling, traction control, gauges not working etc. have tried just about everything I can find on the forum. New battery, inspect and cleaned grounds, checked and removed star connectors and just jumpered PCM & BCM, car won’t start and getting PCM no comm as well as comm codes for TCS, BCM, SDM. Any suggestions other than pulling the PCM and send it out for test/reprogram?
Old Oct 9, 2018 | 05:42 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
So I see you removed both star connectors shorting bars AND jumpered the PCM/BCM and it still didn't start ??....MMMM ???...which grounds did you clean ??...G106 near the battery ??...the PCM ground is there (black/white wire)...PCM won't work if you have power there but no ground...I just went through some crazy stuff with my '01 last week (P1518, no start, no comm...blah,blah, blah...low battery voltage on DIC... no fuel pump prime...cycled the key on and off a bunch of times and car started so I will changing ignition switch soon....I also cleaned G106 ground...if you jumpered the PCM and you KNOW the ground is good just check for a 5 volt ref. at the MAF sensor real fast KOEO....the yellow wire !!...also PCM fuse...can't remember the number....feeds the control side of ignition relay 42 ...that I remember...LOL !!!
Old Oct 9, 2018 | 08:10 PM
C5 Diag's Avatar
C5 Diag
Dude, what year is your car ??...and it ain't a '75 ???...LOL !!!
Old Jan 18, 2019 | 10:25 PM
Dave Mitchell's Avatar
Dave Mitchell
Cruising
MAF doesn't have 5v ref. Only 12v supply and signal back to PCM. I did find 5v ref on TAC yellow/black wire.
Old Jan 18, 2019 | 10:48 PM
C5 Diag's Avatar
C5 Diag
The MAF has a 5 volt ref. on the yellow/black wire...that 5 volts gets pulled to ground by the MAF sensor...it makes a 0-5 volt square wave !!
Old Jan 20, 2019 | 08:00 PM
bighank's Avatar
bighank
Default Mine was the Ignition Switch
Had no start and P1518 code pointing to TAC and no communication to PCM. Checked out wires from TAC to TB motor and position sensor, PCM, and accelerator pedal sensors. Replaced TAC. Car cranked fine but wouldn't start. Replaced Ignition Switch. Car started right up. Let me know if you need a TAC. I have one gathering dust.
Old Jan 24, 2019 | 10:53 PM
Dave Mitchell
Cruising
Originally Posted by c5 diag
dude, what year is your car ??...and it ain't a '75 ???...lol !!!
1998
To PCM no comm
