Rear End Question
Old Oct 26, 2002 | 06:59 PM
karshop's Avatar
0karshop
Former Vendor
Default Rear End Question
I have two rear ends-one is a 3:15 the other is a 2:79?. when you look at them from the front where the trans. shaft goes, one is solid except for the shaft hole. The other has an opening where you can see the gear..The 3:15 is the solid one. Whats the difference in the rwars other than ratio?
Old Oct 26, 2002 | 07:43 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Rear End Question (karshop)
the housing of the 3.15's is stronger then the other one. If you were going to rebuild a Carrier (rear end) you would want the 3.15 or 3.45 housing to rebuild. :smash:
vetterdstr :cheers:
Old Oct 26, 2002 | 08:26 PM
karshop's Avatar
0karshop
Former Vendor
Default Re: Rear End Question (vetterdstr)
The 3:42 i had had the carrier with the cut out in it also>
Old Oct 26, 2002 | 08:28 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
The plate you are missing is probably still attached to the trans they came off of.
Old Oct 26, 2002 | 08:47 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Difference is one is missing the rear plate. Automatic cars have the plate six speeds don't. Both rears can be used for either application. The (2.79) if from a Corvette is a 2.73 :yesnod:
Bob
Old Oct 26, 2002 | 08:54 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Rear End Question (16Again)
ding... ding... ding we have a winner(s)!
Old Oct 26, 2002 | 10:38 PM
karshop's Avatar
0karshop
Former Vendor
Their is no plate missing, when i pulled the trans off of both i did both the same, one actually has a cut out where you can see the ring gear and the other on does not.
karshop's Avatar
0karshop
Former Vendor
Default Re: Rear End Question (Mike Mercury)
both transmissions are the same, no plate
Old Oct 26, 2002 | 10:58 PM
Mike Mercury
this one has the plate:
this one does not:
its a must with the A4.
To Rear End Question
