O2 sensor code?
Old Oct 16, 2018 | 03:54 PM
Brads101's Avatar
Brads101
Cruising
Default O2 sensor code?
Hi everyone,
I’m from over in the UK and I have just had the error code come up after having a run and opening the car up....
It has had a remap by previous owner due to aftermarket exhaust, but has never had the code come up before..
P0137 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
Could it be a faulty sensor that just needs replacing??
Many thanks
Old Oct 16, 2018 | 04:29 PM
feeder82's Avatar
feeder82
Yes it could be, or the wiring to the sensor. Check fuse number 15 also
Old Oct 16, 2018 | 04:53 PM
Brads101's Avatar
Brads101
Cruising
Nice one, I will check those out...
Could someone point me to the location of the sensor in question?
thanks again
Old Oct 16, 2018 | 04:59 PM
jamieo's Avatar
jamieo
It would be the driver's side AFTER the converter(downstream).
Old Oct 16, 2018 | 08:10 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
As others have said could be wiring or a sensor. 4 heater DTC’s would set if fuse 15 were blown !!
To O2 sensor code?
