Rocker arm ratio
Old Oct 27, 2002 | 07:29 AM
blktie8's Avatar
blktie8
Default Rocker arm ratio
Anyone ever upped the rockers to 1:8 on a stock LS1 any pushrod issues
any power to be gained ?
Old Oct 27, 2002 | 10:52 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Rocker arm ratio (blktie8)
I installed the Crane 1.8 full roller rockers on my car. The kit came with screw in studs, pushrods and rockers. I used them for over a year, at 4,000 rpms the engine pulled harder than before. I have since taken them off to have a 224 cam installed.
IMO, you would be better off installing a cam instead. It works out to be more.. but you get WAY more results from the cam. :yesnod:
vetterdstr :cheers:
