FlowKooler Hi-Flow Water Pump
Old Oct 24, 2018 | 04:56 AM
roppa440's Avatar
roppa440
Default FlowKooler Hi-Flow Water Pump
I was asking last week about flow direction of the engine cooling system in the LS1 because I wanted to make sure I had all my facts right.
I purchased and fitted a FlowKooler Hi-Flow Mechanical Water Pump only to find it does not in fact work as well as the stock pump. A couple of degrees hotter at highway speed and FIVE degrees hotter at idle in traffic. Even in colder weather.
I will be re-fitting the original pump in the near future.
Old Oct 24, 2018 | 06:57 PM
FreeC5inAZ's Avatar
FreeC5inAZ
Flowcooler are also made from crap quality pumps.
Old Oct 24, 2018 | 08:49 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Why did you think you needed more coolant flow? Do you have something exotic going on under the hood or driving somewhere scorching? (Newcastle, so I assume not!) If it's not boiling coolant, cooler temps aren't going to improve anything. I'd look at the radiator or fans first if more cooling is in fact needed, especially at low speed, as the airside is likely the bigger bottleneck.
Old Oct 25, 2018 | 03:44 AM
roppa440's Avatar
roppa440
I want to keep the temperature down as low as 185F during mid summer if possible for drag racing purposes. My timing slips are remarkably better below 190F and it can get really hot at Santa Pod Raceway mid summer. ;-)
Old Oct 25, 2018 | 03:06 PM
gimp's Avatar
gimp
Did you already upgrade your radiator?
A DeWitt's setup or similar + SPAL fans do super well at cooling.
Old Oct 25, 2018 | 03:54 PM
roppa440's Avatar
roppa440
I will look into that. If there is a more efficient radiator the same physical size (or close) then that might be an option. I want to keep things looking original as possible on the car so don't want to do anything that would be too obvious.
Truth is that the original radiator and fans do work. I am running a 180F thermostat.
When sitting in traffic and the temp goes up over 190F all I have to do is stick the trans in neutral and increase the rpms to 1500 rpm. The temperature comes straight back down. So a pump that was actually more efficient at idle, which is what I thought I was buying, would have done the trick.
The water temp never gets below 183F no matter how cold the weather which is probably where the 'stat is stable. But at 70+ mph cruise the water temp usually hangs around the 185F mark. Oil temp runs about 192F at that point. Which is fine because obviously it needs to be hotter to burn off any condensation in the block.
Old Oct 25, 2018 | 08:07 PM
gimp's Avatar
gimp
A DeWitt's rad + SPAL fan setup will fit under the stock shroud, as near to plug and play as you can generally get, and nobody will see the difference.
They'll hear it though. Those fans sound like a little jet engine. Actually louder than my exhaust at hot idle.
Old Oct 26, 2018 | 03:46 AM
roppa440's Avatar
roppa440
I'll look them up. If they draw too much current my Hayden digital fan controller might not like it. Or the wiring for that matter.
https://www.haydenauto.com/Featured%...r/Content.aspx
Old Oct 26, 2018 | 04:36 AM
roppa440's Avatar
roppa440
I just looked up the Dewitts 1139101A radiator. $650. With me being in the UK it will cost me twice that delivered to my door plus taxes.
So I will have to save up for that one and try it with the stock fans to see how it goes. Maybe an early birthday present for my 60th next year. ;-)
Old Oct 26, 2018 | 09:24 PM
gimp's Avatar
gimp
IIRC they draw the same current - or at least, they draw under the fuse amperage.
Now, with radiators, you do have options. Others sell a similarly plug-and-play radiator, some for less money. There are even ~$200 ebay units that some report good success with.
SPAL fans though I think are the under-appreciated hero of this upgrade. A lot of companies can make a double-core radiator with more fluid capacity and thus (unless very poorly designed) more cooling capacity / heat rejection ability, with dimensions to fit where the stock one fits. But the fans really, really draw a _ton_ more air. Like double the airflow / cfm in the same space, with stock shroud, stock harness plug, stock electronics, etc.
$400 though. Plus shipping. Tough.
To FlowKooler Hi-Flow Water Pump
