Most frustrating AC issues
Old Oct 24, 2018 | 05:29 PM
Evan Benson's Avatar
Evan Benson
Default Most frustrating AC issues
Replaced ALL of my ac components a few months ago, worked great for awhile. Its been cold the past few weeks so havent had to use the ac. Now the AC doesnt blow any cold air, compressor works and comes on just fine, ac light on. Its fully charged, with no leaks whatsoever. It is the dual climate system and it is around 50 degrees outside, will it not blow cold ac air because its colder outside than the coldest setting? There should be no reason to why its not cold, for whatever reason the other day when I turned it back up to 77 degrees it blew cold for a few minutes. I have no clue, any help would be greatly appreciated.
Old Oct 24, 2018 | 08:23 PM
redzg's Avatar
redzg
The ambient temperature is displayed more-or-less accurately? I.e. if it's warm out it doesn't read 69? If you turn the temperature up does it change the output air temp to warmer, indicating the blend door is working? If the blend door actuator died in a warm position, that might keep the A/C from being terribly effective.
