Horn switch membrane
Old Oct 30, 2018 | 03:39 PM
Robrote's Avatar
Robrote
Default Horn switch membrane
How much of a PIA is this horn membrane going to be to install? Should I just look for a used wheel, or replace the switch?
Old Oct 30, 2018 | 04:19 PM
Moved to C5 Tech.
Old Oct 30, 2018 | 04:27 PM
GCG's Avatar
GCG
Take a look at this step-by-step. It might give you the answers you're looking for
If you need to purchase it, you can get it here.
Old Oct 30, 2018 | 11:01 PM
johnson-rod's Avatar
johnson-rod
You could try cleaning it. I used CRC's QD Electrical Contact Cleaner. Seems to be working. It's been over a year.
Old Oct 31, 2018 | 02:36 PM
UM Rebel's Avatar
UM Rebel
I helped a friend replace his on a 2001 coupe. It was not hard at all. Like GCG said above, just follow the video. The only different advise I will offer is don't cut those rubber tabs with a utility knife. Just reach in there with a pair of wire pliers and snip them. Easy peasy and you don't risk cutting through the steering wheel cover.
To Horn switch membrane
