Why are these codes popping up?
Old Oct 28, 2002 | 02:17 AM
Quick Brick's Avatar
Quick Brick
Default Why are these codes popping up?
I think these are related to the active handling codes but I did not racord them yet. Anyway, check engine light and a P0113 and P1111 both are IAT high voltage, and intermittent high voltage. Any ideas? TIA :seeya
Old Oct 28, 2002 | 02:51 AM
z0sense's Avatar
z0sense
Default Re: Why are these codes popping up? (Quick Brick)
Bad IAT sensor or it may not be connected correctly.
If you still get the problem with active handling warming up.....this is what would cause it.
I would also like to say that if it is giving a high signal reading then it will cause a rich condition. In addition to being untuned with the cam.
When it was pulled off it may have got something on it, or it may have had a wire pulled out of it, etc.
Try replacing it.......only a couple of bucks.......i think, or switch to the Z06 MAF.
Old Oct 28, 2002 | 10:32 AM
Quick Brick
Default Re: Why are these codes popping up? (z0sense)
Yeah it has been running "different" at idle too. More surging and lope than normal. I think the 02 MAF requires a different harness plug? I'll pick up and IAT anyway. My EASE is not working properly!
Old Oct 28, 2002 | 11:45 AM
z0sense's Avatar
z0sense
The MAF does require a different harness, but you can pick that harness up cheap. It is a little larger MAF, butI am not too sure it will benefit you more. I just like it because of the integrated IAT.
D.
To Why are these codes popping up?
