Car is a 03 Z06 with factory manifolds+midpipe and a OBX looking catback (6.5" diameter and ~12-14" long straight through mufflers). Sound volume is nice, minimal drone inside and barks when you want it to.
However, on decel and or light throttle (even idle) there is a hint of this flutter/wet burble sound mixed in with the overall tone of the exhaust. Any way this is related to what I read about the factory H pipe having only a 1/2" diameter hole in the crossover tube? I have thought to cut it apart and open up the hole (if it's really only 1/2") but at that point I might as well go right to an x pipe (I always like X over H pipes). If this small hole is not the cause of the noise then I won't bother.
I tried searching but wasn't too sure what works would trigger the right results lol.
Sounds like you found the information you were needing -- reported multiple times to be the small hole in the factory H causing that wonderful boat burble. Also some interesting references -- including Engine Masters on YouTube/Motortrend -- that the X actually does add just a scintilla of power over the H.
Thanks for the confirmation. I'll most likely cut out the H pipe and replace it with a properly designed X pipe. I might look into calculating the proper placement downstream as well.
In general the further upstream is all the better...
Interesting. What are you basing this off of? All the aftermarket cookie cutter x pipes have the x downstream a bit. I assume so they can offer room for catalytic converters...
