Coolant clean up/gasket questions
Old Nov 7, 2018 | 09:39 PM
1999corvettels1's Avatar
1999corvettels1
Default Coolant clean up/gasket questions
Doing A/C compressor replacement, just pulled water pump, one bolt on driver's side wouldn't come out all of the way because it hit the ABS module, so will have to remember to put it back in hole of water pump before getting it lined up on block.
Anyways, coolant got all over the a/c drive belt, and main crank pulley.
The belt is only a year old, so I want to reuse it, do I need to really clean the coolant off belt and crank pulley, or is it not that of a big deal other than wiping it off with paper towels?
I have simple green.
Also on water pump gaskets (my first LS water pump replacement, but reusing pump) would it be ok to use a little RTV sealer to hold the gaskets (metal fel pro) to the water pump like you do on old SBC and BBC water pumps?
Old Nov 7, 2018 | 09:48 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
just flush the belts and other parts with water, I also use a dab of silicone to hold gasket in place !!!
Old Nov 7, 2018 | 09:57 PM
1999corvettels1
Awesome, thank you!
Old Nov 7, 2018 | 10:01 PM
1999corvettels1
One more thing 4 out of the 6 bolts have some crust, the top 2 are clean, have poked holes in cardboard box to keep them in order.
Wire brush them or not?
Any sealant needed on threads?
Old Nov 7, 2018 | 11:13 PM
Moved to C5 Tech.
Old Nov 8, 2018 | 01:28 AM
TastyBacon's Avatar
TastyBacon
Yes, wire brush the bolts. Don't put anything on the threads. I agree with Pounder, the belt will be fine and a little dab of silicone to hold the gasket in place does no harm. Good luck!
To Coolant clean up/gasket questions
