18 HP Performace gain from Hypertech PPIII
Before:
350,8 HP (SAE cor.) = 258 KW at 5610 RPM, Max torque 356 ft/lb at 4590 RPM, Engineoil temp. at 110 Degree Celsius
After:
368,5 HP (SAE cor.) = 271 KW at 5720 RPM, Max torque 368 ft/lb at 4660 RPM, Engineoil temp. at 90 Degree Celsius
Together with the tuning i raised the engine limiter by 100 RPM.
Thats a gain of about 18 HP and 12 ft/lb just from the Hypertechtuning. I was "shocked" when i saw the results, because most of the people here in the Forum reported no gain at all from this tuning process.
Here the link to the printout from the run. Dont get fooled by the numbers. On the left ist Kilowatts and on the right its Newtonmeters. Both get tranfered by 1,3569 to the appropriate US values.
Jochen
http://www.corvetteforum.de/attachme...12764849fae139
[Modified by Jochen, 10:10 AM 10/28/2002]
[Modified by lost, 5:20 PM 10/28/2002]
Don't waste your time with a cooler thermostat unless you get something (chip, fan controller) to change the on/off settings of your electric fans. The engine won't run much, if any, cooler without changing the fan on temps as well.
[C5-VERT responded]
The Hypertech PPIII does allow you to change fan on/off settings...
Stock Run 323 HP at 5600 RPM
Run No. 2 350,8 at 5610 RPM (this includes all the Modifikations you can see in my signature)
Run No. 3 368,5 at 5720 RPM added Hypertech and stat.
I know these numbers sound high, but thats what the machine told us :yesnod:
Jochen
