Could anyone tell me if the DIC switch cluster can be removed without pulling the gauge cluster? Do they pop out from the front like door switches? Also I'm looking for a set of LED bulbs in blue that just plug into the door and DICswitch and fog, shifter and dimmer switches.Are these available and where? Thanks in advance.
Have to remove the cluster just for the switch buttons?
Yes. Not the simplest light replacement but with good LEDs the lights should be good for many years.
Edit: As chris308 mentioned, there are several vendors on the forum that sell interior LEDs in different colors. The ones that come quickly to mind are Radioflyer Innovations; Vette-Lights; and JW Motorsports. Fortunately, the other interior lights are much easier to swap out than the DIC lighting.
Reason: Added comment
