Rear half shaft
Old Nov 10, 2018 | 03:53 PM
helga203's Avatar
helga203
Default Rear half shaft
99 c5 mn6, I was helping a friend take his TT out and when i went to pull the half shaft it come apart from the spline in the rubber boot. The rubber is not damaged or leaking anything. I though his joint in side the boot broke but that wasn't the case. The car runs fine and no noises and he can do a burn out , break torque no problem. What gives is that normal that the shaft is two pieces???
