I'm stoked!!
I'm hoping to get low low 12's out of this setup with tires.
I also found out I have accpetable piston to valve clearance with the new heads/cam setup for my T/A so that will go back together this week and hopefully I'll be running mid 10s by Dec. :)
Today is a good day! :D
And good luck with the Vette too, I have no doubt you'll be in the 12s with those mods. If you put on a better set of tires you'd probably already be in the 12s, those runflats suck for traction.
awk408,
I changed the heads AND cam. The new heads are milled and set up for 11.4:1 compression. My AREs are 10.8:1. Also this new cam although smaller in dur is much higher in lift and has a much faster ramp rate so the combination is close. The guy I bought it from dyno'd 437rwhp, 419rwtq with so I'm crossin my fingers. :)
Ohh, I forgot to mention I already went 12's on Sat with DRs and deleting TQ managment. :) 12.91@107.4 1.97 60' :)
Guess I need to go change the sig.
:rolleyes:
So whats up with your set up bro? Have you sent em out yet?
awk408,
:rolleyes:
I'm crossing my fingers for you, I hope you get those #s. With a higher lift cam and higher CR, it won't be an apples to apples comparison, but we both know 365RWHP won't cut it. That's a joke.
I'm hoping to start taking my heads off this weekend. Did you send yours back already?
The heads are 5.7L but they were welded up to resemble 5.3L heads with very small ports. They were also milled some.
I know it is not a great comparison but at this point I am so sick of having no power that I am not waiting around. I will propbably just put the AREs on my Vette.
I just got the last head off yesterday so I will be shipping them out on Monday. I should have the new stuff on and done by Sunday or so. I'll cross my fingers for you bro. :)
