Window activation noisy
Old Nov 20, 2018 | 12:36 PM
37pat's Avatar
37pat
Default Window activation noisy
My ‘03 Z06 recently, and seemingly immediately, began making “crunching” or “crackling” sounds each time I raise or lower the driver’s side window. The noise resembles what I’d expect of a bunch of broken glass inside the door. The noise stops when the window stops moving. I’m thinking this is a broken gearing problem in the regulator motor, but was hoping someone here could either confirm this diagnosis, or offer a reasonable alternative. T.I.A.
Old Nov 20, 2018 | 12:38 PM
STRMLNE's Avatar
STRMLNE
I have the same exact problem right now. Just bought a window reg and motor on amazon. Going to replace it this weekend. Instructions look somewhat straight forward.
Old Nov 20, 2018 | 12:42 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
YES !!...bad window regulator...mine making the same noise 6 months ago...stick with OEM !!
Old Nov 20, 2018 | 01:03 PM
STRMLNE's Avatar
STRMLNE
I believe Dorman is oem. I bought AC Delco which should be fine.
Old Nov 20, 2018 | 01:40 PM
C5 Diag's Avatar
C5 Diag
Dorman is NOT OEM...AC Delco is...and as Eric O from South Main Auto says..."Dorman is El Junko" !!...stay away from their stuff !!
Old Nov 21, 2018 | 12:48 PM
lionelhutz's Avatar
lionelhutz
I'd leave the window up too until you fix it, unless you are OK with the window getting stuck down.
Old Nov 26, 2018 | 12:34 PM
37pat's Avatar
37pat
Oh, yeah! Window remains up. Should be ordering new regulator today/tomorrow. Thanks for the head’s up though.
Old Nov 26, 2018 | 04:48 PM
STRMLNE's Avatar
STRMLNE
I just ordered the drivers side AC Delco on Amazon. It appears as though the passenger side requires the new weather pack connector but the drivers side does not for some reason. I get the part tomorrow. I’ll let you know what I find.
Old Nov 26, 2018 | 04:49 PM
STRMLNE's Avatar
STRMLNE
Are you changing it yourself? I have everything disassembled but am having a hell of a time getting the glass out despite loosening the clamps. Going to wait until I get the part before I try again.
Old Nov 26, 2018 | 05:32 PM
UM Rebel's Avatar
UM Rebel
I replaced both regulators on my 04 CE about 2 years ago. Pretty easy job after you watch the videos. Here's one
I used the el cheapo regulators off eBay.
https://www.ebay.com/itm/97-04-Chevy...frcectupt=true
No problems.
Old Nov 26, 2018 | 06:07 PM
STRMLNE's Avatar
STRMLNE
I watched your YouTube video. Wish you would ya r given more detail how you got the glass out and what adjustments you made after installation so the glass lines up properly. These seem to be the main issues.
Old Nov 27, 2018 | 02:04 PM
UM Rebel's Avatar
UM Rebel
After you loosen the two bolts that clamp the glass in the regulator just grab the glass and pull it straight up and out.
As far a lining up. I marked on the glass with a sharpie where it was in old regulator and put it back in same place on new ones.
Like I said, no problems.
BTW that was not my video. Just one I found. There are several others out on youtube.
Old Dec 6, 2018 | 10:00 PM
az57chevy's Avatar
az57chevy
I used a grease marker to ote glass location. Wiggle the glassand it will come up
Try this video
Old Dec 9, 2018 | 03:36 PM
STRMLNE's Avatar
STRMLNE
Thanks. Got everything out back together. Did you have any issues with the glass rubbing slightly. I can hear it touching something on the way down. I tried tweaking the two bottom adjustments tilting the glass in or out slightly but it still sounds like it’s rubbing. Not sure if putting he door panel back on will fix the issue.
To Window activation noisy
