Is F45 the same as active handling
Old Oct 28, 2002 | 09:41 PM
1 slow 97's Avatar
1 slow 97
Default Is F45 the same as active handling
I hope this isn't a stupid question, but I hear alot of people say active handling suspension. On my 97 I have the F45 suspension with the adjustable **** on the center console. Are these the same or something completly different? Also, my buddy can put his car in competition mode. Is that what active handling is? Thanks!
Old Oct 28, 2002 | 09:55 PM
Mark VerMurlen's Avatar
Mark VerMurlen
Default Re: Is F45 the same as active handling (1 slow 97)
F45 is also known as "real time damping". Its adjusting the shock valving based on the **** setting and the suspension inputs it receives.
"Active Handling" usually refers to the use of the braking system to help prevent spinning the car. The computer can apply a single brake on one of the wheels to counter a spin. Look at GM's Corvette web site for an animation of who it works.
I forget the exact year Active Handling was introduced, but I think it was 2000. So I don't think your car has it.
"Competition Mode" is engaged by holding down the traction control button for a few seconds. Normally the traction control button turns on and off both traction control and active handling (if you have it). In competition mode, traction control is turned off, but active handling is still on.
Hope this helps.
- Mark
Old Oct 28, 2002 | 10:05 PM
jschindler's Avatar
jschindler
Default Re: Is F45 the same as active handling (Mark VerMurlen)
What he said.
Old Oct 28, 2002 | 10:15 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Is F45 the same as active handling (jschindler)
Active Handling was introduced mid year in '98 as an option.
all Pace Cars got it as part of the Z4Z option. :cheers:
To Is F45 the same as active handling
