3.42 SWAP WITHOUT PULLING TRANSMISSION?
Old Oct 29, 2002 | 11:18 AM
batsallover's Avatar
batsallover
Default 3.42 SWAP WITHOUT PULLING TRANSMISSION?
Is this possible? :confused:
There are threads where it says a diff can be swapped with proper support on the transmission.
:confused:
Old Oct 29, 2002 | 11:34 AM
wkasak_07Z06's Avatar
wkasak_07Z06
Default Re: 3.42 SWAP WITHOUT PULLING TRANSMISSION? (batsallover)
:confused:
I think Eastcoast Transmissions pulled the gear assembly before removing the trans. Check out... http://members.tripod.com/eastco/2001vett/
:cheers:
[Modified by wkasak_98Coupe, 3:36 PM 10/29/2002]
Old Oct 29, 2002 | 11:46 AM
Mike Mercury's Avatar
Mike Mercury
Default Re: 3.42 SWAP WITHOUT PULLING TRANSMISSION? (wkasak_98Coupe)
Michael... my man. I did not pull the tranny. :)
Old Oct 29, 2002 | 11:47 AM
KingTut's Avatar
KingTut
Mike Mercury docummented his DIY gear swap on his web site. I also watched very closely as mine was done and the transmission was only lowered some but it was never removed or disconnected from the TC.
You have to disconnect the air bridge and be real careful just how low you tilt the transmission or the engine will "hurt" your fire wall as it tilts with the transmission.
My best advice is to find his web site and read it over real good.
Old Oct 29, 2002 | 12:02 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Default Re: 3.42 SWAP WITHOUT PULLING TRANSMISSION? (KingTut)
Bats, did you get a gear box or just preparing??? Mine is at the doctors office getting all the mods in my sig right this moment (except the intake and exh.)!!!! I cannot wait until I can pick it up which unfortunately will be Sunday as I am out of town with work. Should give them plenty of time with the LS1 Edit to make it just right. :cheers:
Old Oct 29, 2002 | 12:10 PM
batsallover
Default Re: 3.42 SWAP WITHOUT PULLING TRANSMISSION? (sweetcharity)
I am just preparing right now. I am having an unbelievable time finding a used 3.42. :(
Most places that do a 3.90, 4.10 for a 3.42 are looking for at least a 3.15 for an exhange.
Does anyone have a 3.15 they want to get rid of cheap so I can use for an exhange + $$$$??? :(
Old Oct 29, 2002 | 01:18 PM
buzzme's Avatar
buzzme
I got mine from:
Genes Kar Shop
Gene Coggins
P.O.Box 560
Kathleen, Fla. 33849I
karshop@tampabay.rr.com
I couldn't put my finger on his phone number. You may try infomation. It was used with (I think) around 25k on it.
Not necessary to take off the transmission. :smash:
Where is Fairfield? I am about 15 SW of Canton? If I am close, I am willing to help. Wheather is to the place that it will soooooon be time to put the cars to :sleep: for the winter. :cry
[Modified by buzzme, 12:25 PM 10/29/2002]
To 3.42 SWAP WITHOUT PULLING TRANSMISSION?
