Left rear tire flat dic?
Old Oct 29, 2002 | 01:40 PM
c5a4's Avatar
c5a4
Default Left rear tire flat dic?
I get a left rear tire flat, performance reduced to 55 in the dic when I first start my car, then when I drive a few hundred feet and I hit the reset button and it goes from 0 to the correct pressure?
Old Oct 29, 2002 | 03:55 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Re: Left rear tire flat dic? (c5a4)
two things come to mind.
the sensor could be going bad. the other three working ok?
you might try reprogramming it. the procedure can be found in the c5 tech tips section.
good luck
rock
Old Oct 29, 2002 | 05:24 PM
c5a4's Avatar
c5a4
Default Re: Left rear tire flat dic? (ROCKnROLL)
Yes the other three are fine. I will try out the reprogram tip. Thanks
To Left rear tire flat dic?
