Pushrod length calculator inside!
Old Oct 29, 2002 | 05:21 PM
C5Noir's Avatar
C5Noir
Default Pushrod length calculator inside!
First measure your stock cam's base circe diameter. This is the widest point on the intake and exhaust lobes. Punch this into the stock cam base circle diameter.
Repeat this for your new cam's intake and exhaust lobes in the labelled cells.
Finally, if you milled your heads put in how much they were milled, i.e. 0.010 milled.
This will spit out the length of the pushrods required for your new cam and/or heads set-up. Thanks to Allcammedup for getting me straight on the math :cheers:
Here ya' go: http://home.insightbb.com/~l.proctor1/p-rod.xls
Enjoy!
This assumes stock spring installed height for an LS1. The stock pushrod size is base on an LS1 stock pushrod.
[Modified by C5Noir, 3:27 PM 10/29/2002]
Old Oct 29, 2002 | 11:52 PM
Chris@SD's Avatar
Chris@SD
Default Re: Pushrod length calculator inside! (C5Noir)
Looks like a good rule of thumb, but don't rely on this. You need to theck the geometry on each application.
Old Oct 29, 2002 | 11:54 PM
C5Noir's Avatar
C5Noir
Default Re: Pushrod length calculator inside! (Chris@SpeedDemon)
Chris, what else can I account for to make it a better tool? Thanks.
To Pushrod length calculator inside!
