Code 1518
Old Dec 12, 2018 | 11:05 AM
99blkfrc99's Avatar
99blkfrc99
Default Code 1518
On my way to work this morning and car cut out and went into REP. Code 1518 current. Where do I begin? Thanks in advance friends.
Old Dec 12, 2018 | 11:34 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I'd clear the DTC and see if it comes back. P1518 can set if battery voltage is low. Also check that "THROT CONT" fuse is good and is powered and then I'd probably disconnect the TAC module harness and check the wiring down there... You can start there !!
Old Dec 12, 2018 | 11:52 AM
99blkfrc99's Avatar
99blkfrc99
I clear it and it comes right back. Hmm.
Old Dec 12, 2018 | 12:01 PM
C5 Diag's Avatar
C5 Diag
It came back right after you started the car ??...if car cranks normally it's not the battery...you can check the other items !!
Old Dec 12, 2018 | 12:32 PM
99blkfrc99's Avatar
99blkfrc99
Yeah. It cranks and runs just fine.
Old Dec 12, 2018 | 12:48 PM
C5 Diag's Avatar
C5 Diag
If the THROT CONT fuse is blown there is no throttle response...you push the accelerator pedal down...and NUTIN" happens !!
Old Dec 12, 2018 | 04:10 PM
99blkfrc99's Avatar
99blkfrc99
So if fuse, power and ground are good to the module then it's "most" likely the module. If the fuse is popped I have a short to ground on the pink wire leading to the module? Reason I ask is the yellow and brown wire from the throttle body are routing under it. If suppose one of those touched ground would the fuse blow? Thanks.
Old Dec 12, 2018 | 04:58 PM
C5 Diag's Avatar
C5 Diag
Yes, if the pink wire that goes from the THROT CONT (17) fuse to the TAC Module is shorted to ground the fuse will blow. With the ignition OFF do you have voltage at the fuse ??...(if so that pink wire is shorted to power somewhere and will set the DTC)...you should only have power there with key ON or START. I'm assuming the brown and yellow wire you are taking about is the TAC motor ??...I don't have an FSM wiring diagram in front of me but if I can remember that DTC will set if there is a short to voltage on the TAC Module ground circuit too...it's probably a black or black/white wire. You can also have some wiring issues at the TAC motor also. Sorry I can't give you more help right now. Before you fire the parts canon I'd check the wiring.
Old Dec 12, 2018 | 05:10 PM
C5 Diag's Avatar
C5 Diag
Now that I'm thinking about it I had starting issues with my own '01 about 2 months ago...was a P1518 and I also had a R.E.P. and "low voltage" on the DIC which I knew was false. My battery and charging system are fine. My first thought was a bad ignition switch so I cycled the key a bunch of times thinking there was some corrosion on the ignition contacts...car started fine after that and couldn't duplicate the problem. Changed the switch and everything is OK now...did the car "cut out" while driving ??...that too can be a bad ignition switch !!
Old Dec 12, 2018 | 06:11 PM
99blkfrc99's Avatar
99blkfrc99
Just got home so Ima dig into it. Thanks for your knowledge.
Old Dec 12, 2018 | 09:11 PM
C5 Diag's Avatar
C5 Diag
Wiring from the FSM on its way...let us know if Fuse 17 blows again !!
Old Dec 13, 2018 | 10:30 PM
99blkfrc99's Avatar
99blkfrc99
Thanks to rwobs for the troubleshooting help found the tac motor wires, yellow and brown, were routed under the snout of the intake. The yellow rubbed on the steam pipe which caused the short I was after. Fixed harness and re routed wires and all good now.
Old Dec 21, 2018 | 08:08 PM
bighank's Avatar
bighank
Default Mine was a bad igniton switch... Have a extra TAC if you need one
Went thru hell testing all leads from TAC to TB, PCM, and accelerator pedal. NO DICE. Ordered a TAC and replaced it. NO CHANGE. Car world crank but not start and produced a P1518 code every time. Replaced Ignition Switch (rear part only D1499C) and car started. If you need a TAC I have one gathering dust.
BIGHANK
Old Dec 25, 2018 | 12:21 PM
fnterasa's Avatar
fnterasa
7th Gear
How do I clear a check engine light?
Old Dec 25, 2018 | 03:33 PM
helga203's Avatar
helga203
do a search tons of directions how to do it.
To Code 1518
