Replace or hold??: Lifters and oil pump
Old Dec 12, 2018 | 01:17 PM
turabo87's Avatar
turabo87
Default Replace or hold??: Lifters and oil pump
Hi forum,
I’m on a crossroad and I wanted to pass this by the forum before deciding. I’m upgrading my cam to a mild Jegs .585/.585 and along with this comes dual valve springs, titanium retainers, gaskets, harmonic balancer...etc. These are some of the non negotiable items that come with the upgrade and come in the “must do while you’re in there”. However, what seems to be optional and preferential is to replace the lifters again with just fresh OEM hydraulic rollers and replacing the oil pump for a high volume Melling unit.
My rational and cost effective mindset is that I should save from replacing those items because at 90k miles I have very strong oil pressure readings and zero valvetrain lifter noise.
What do you guys think? Is there data to back this up or should I bite the bullet and replace lifters and oil pump for insurance?
Old Dec 12, 2018 | 01:22 PM
aaronc7's Avatar
aaronc7
Personally I would do the oil pump while I was there... it's right there, super easy to swap and parts cost is small compared to the work involved in the cam swap. If you want a small 'upgrade' on the oil pump, check out the melling standard volume high pressure pump 10295 i think is the PN.
Lifters on the other hand would require pulling the heads, which is going to add a lot more work (I spent a ton of time cleaning the bolt holes, gasket surface, all while bent over in a non comfortable position). I would skip on the lifters unless you are porting or replacing the heads too.
Old Dec 12, 2018 | 01:25 PM
helga203's Avatar
helga203
Like he said. Oil pump . Lifter will be fine
Old Dec 12, 2018 | 02:04 PM
turabo87's Avatar
turabo87
Ok, but if I do change the oil pump, do I go for the higher volume Melling or OEM spec pressure/volume? Like I said, I have zero oil pressure issues. Oil pressure profile is mighty strong right now, and motor is at 90k miles.
Old Dec 12, 2018 | 02:13 PM
05MBMGTO's Avatar
05MBMGTO
No reason not to replace the oil pump and timing chain while your literally right there. Ive used the Melling 10295 as Aaronc7 stated above and the basic LS2 chain in multiple LS builds with no issues. Also might want to invest in the rocker arm trunion upgrade as well. LS1 rockers are known to spew out their needle bearings and with 90k on yours it would be a sound investment. You can buy the kit and install them yourself or a few companies (BTR, Michigan Motorsports) sell already upgraded rockers with a small core charge. I personally have always used the Michigan motorsports kits for $199 with the comp cams or BTR trunion upgrade already done.
Old Dec 12, 2018 | 02:28 PM
aaronc7's Avatar
aaronc7
The 10295 is basically a stock size pump but comes with a higher bypass spring. So expect similar oil pressure in most of the rpm range, just a little more (10 psi?) pressure in the upper rpms under wide open throttle. I don't think you need/want to go to a physically larger geared oil pump if if's still a stock engine with oem bearing clearances and such.
I also did the LS2 chain and rocker arm upgrade when I swapped my cam.
Old Dec 12, 2018 | 02:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
Lifers are probably fine at that mileage but cheap enough (if it were me) Id replace them.
Cant see any reason to replace the oil pump. Not a fan of high volume pumps unless you run more clearance. Its just not needed, opinions will vary
after 182k still have 42psi hot on the original pump .Thats way more than it needs.
Old Dec 26, 2018 | 09:54 AM
turabo87's Avatar
turabo87
It's funny how I started with the "budget build and cutting corners" mentality, and ended up now with the "I'm gonna hate myself if this gives me problems later on, let's change it while I'm there" mentality. I bought the 10295 oil pump, LS2 chain, and LS7 lifters and trays. I ended up getting the lifters because my strategy for the build changed and I'm going to end up taking the heads out anyways. I learned that the methods to safely change the valve springs without removing the heads is actually a major PITA and slower process than just taking the heads out and changing the springs outside. So I bit the bullet with new lifters and trays too.
Old Dec 26, 2018 | 08:54 PM
RedTRex's Avatar
RedTRex
I was getting ready to ask about changing springs without removing the heads until I came across your post....guess this about sums it up. Thanks!
Old Dec 26, 2018 | 09:37 PM
frodo84's Avatar
frodo84
Uneducated autodidact
I wouldn't put a new cam in with the old lifters.....my opinion. Good luck with your build.
Old Dec 27, 2018 | 10:30 PM
redzg's Avatar
redzg
I haven't done it yet, but it sure seems centering the oil pump can be tricky at times -- with good pressure I would be severely tempted to leave well enough alone. Both high pressure and high volume come at a HP cost.
But if it blows up, I will be saying something to the effect of 'sure glad it isn't mine'...
Old Dec 28, 2018 | 06:54 AM
turabo87's Avatar
turabo87
I’m halfway into the build already and the amount of work going in is not to be underestimated. Realizing this now I DO NOT want to have to go in there again that deep into the engine anytime soon. Old pump has already 90k miles and will probably last another 90k but I’m not going to risk it due to the amount of labor to get in there. Also, I’d rather have that extra piece of mind at this point.
Old Dec 29, 2018 | 05:57 PM
redzg's Avatar
redzg
Yeah, I just re-read my post and couldn’t help but think “what a load of crap” for exactly the reasons you state.
Now though - high volume, high pressure, both, neither?
Old Dec 29, 2018 | 06:12 PM
turabo87's Avatar
turabo87
Lol, no harm done. I got Melling PN 10295, which has stock volume but relief pressure spring is higher for about 10-15 psi more up top.
Old Dec 29, 2018 | 06:23 PM
frodo84's Avatar
frodo84
Just a suggestion....think about using a "girdle" for the pump pickup to prevent o-ring issues....
http://www.improvedracing.com/oil-pu...amp-p-642.html
Old Dec 31, 2018 | 04:41 AM
opel's Avatar
opel
You might want to look in to a timing chain dampener as well.
Old Dec 31, 2018 | 02:58 PM
foggy's Avatar
foggy
I did my spring change with heads on... Was Way Easier than I thought it would be.... But, If you are taking the heads of anyway.. then
of course do it while theyre off..
But I wouldn't go thru the work of removing the Heads Just to Do Valvesprings...Easy enough on the engine.
Just my 2 Cents
Old Dec 31, 2018 | 03:05 PM
monteholic's Avatar
monteholic
I would never re-use lifters on a new cam...roller or not, esp ones that have 90K on them
Old Jan 3, 2019 | 01:08 PM
turabo87's Avatar
turabo87
I just thought I would provide an update and maybe some closure to my thread (you guys are welcome to keep commenting though). I took the heads off to change the valvesprings more comfortably and permitted me to change the lifters. I went with genuine OEM LS7 lifters and trays. New oil pump went in too (10295 with its 10% higher pressure spring) and a new LS2 chain. That's about it. My LS1 didn't come with a damper and I left it as is. The work is done already and cylinder heads are back on the motor torqued and everything.
To Replace or hold??: Lifters and oil pump
