healthy daily driver '97, turn key tonight after having set for couple hours = click, nada
Old 10-29-2002, 07:47 PM
Red Gump
Red Gump's Avatar
Default healthy daily driver '97, turn key tonight after having set for couple hours = click, nada
very strange. no prior issues with her at all, meter has always read normal, no hesitation on start up ever, then today--I come home at lunch, get back in around 5, turn the key and CLICK, blank out. pop the hood, no hood light. clicking noise from engine compartment. key is out, guages are going crazy. hook up the charger, clicking increases in loudness and frequency. posting from home so pages load very slow so I didn't do a search yet. any ideas? :seeya
Old 10-29-2002, 08:09 PM
Blue 02 C5
Blue 02 C5's Avatar
dead battery or starter solenoid. check your volts on your DIC, if good (11-13 volts), probably starter solenoid.
Old 10-29-2002, 08:14 PM
Red Gump
Red Gump's Avatar
Default Re: healthy daily driver '97, turn key tonight after having (Blue 02 C5)
dic doesn't even give me a reading. nothing. got to be the battery I'm thinking--guess I'll yank it and go have it checked.
Old 10-29-2002, 08:16 PM
CVCVCV
CVCVCV's Avatar
Sounds like your positive battery post may have broken, you are describing EXACTLY what happened to my C5 when mine broke.
If it's the OEM type Delco battery you have in there then I'd be surprised if this wass NOT the problem.
If so you'll need to get a lot of battery acid out of everywhere under the battery including ther black flex cable covers!
If it has leaked acid flush it out real QUICK before it dissolves your PCM and main cable harness that are directly below the battery!
Perry
Old 10-29-2002, 08:18 PM
WALLstAL
WALLstAL's Avatar
St. Jude Donor '05
Default Re: healthy daily driver '97, turn key tonight after having (Red Gump)
Mine only lasted for 6 month, is that the original? Then it probably over due.
Old 10-29-2002, 08:31 PM
Red Gump
Red Gump's Avatar
Default Re: healthy daily driver '97, turn key tonight after having (wallstAL)
perry, definitely not a post issue, everything is clean. and wallstal, nossir, it's an interstate. pulled it out, running to have it checked. thanks for the input!
Old 10-29-2002, 08:33 PM
00c5coupe
00c5coupe's Avatar
dead battery....happened to me 2 months ago. No prior signal.
Old 10-29-2002, 09:01 PM
CVCVCV
CVCVCV's Avatar
Pleased to hear that !! I would never wish the broken post / acid leak problem on anyone...
...best of luck - I'd agree, it does indeed sound like your Interstate may have gone "out of state" !
Perry :reddevil
Old 10-29-2002, 09:46 PM
Red Gump
Red Gump's Avatar
Default Re: healthy daily driver '97, turn key tonight after (00c5coupe)
just got back--had it tested, DED. slapped a new one in and she's good to go! problem solved, thanks for the input! :cheers: just love it when I can "fix" stuff. :lol:
Old 11-04-2002, 04:10 PM
UFGatorBry
UFGatorBry's Avatar
Default Re: healthy daily driver '97, turn key tonight after (Red Gump)
that's a way to use those fix it skills :cheers:
To healthy daily driver '97, turn key tonight after having set for couple hours = click, nada
Quick Reply: healthy daily driver '97, turn key tonight after having set for couple hours = click, nada
