Ecbm
Old Dec 21, 2018 | 11:03 PM
rickw99vette's Avatar
rickw99vette
Default Ecbm
I have a 1999 C5 and I always have this fear one day I'm going to turn that key and find out my ECBM has gone kaput ! I've heard the horror stories of no replacements (unless you find a used one) and no repairs, am I sitting on a ticking time bomb? Is there any steps to take to prevent a failure ? I've been told to change the brake fluid periodically would help. Don't understand with so many 1997 thru 2000 C5 produced that there is no way to repair. Does anyone know if the ECMB goes out that it can be removed with a computer programmer ?
Tanks
Old Dec 21, 2018 | 11:12 PM
STRMLNE's Avatar
STRMLNE
You can still drive the car even if it goes out. Mines been out for about 2 years now.
Old Dec 21, 2018 | 11:18 PM
rickw99vette
I knew someone had there's go out and the car would not run, computer shut the car down. Looks like to me it would just loose the traction control.
Old Dec 22, 2018 | 09:36 AM
Josephu's Avatar
Josephu
My 98 Silverado has been out for about 15 years! Brakes work fine.. If the light bothers you, just put a piece of black tape over it. Whats wrong with doing smoky burnouts??
Old Dec 22, 2018 | 02:09 PM
UM Rebel's Avatar
UM Rebel
I think battery chargers are the number 1 killer of EBCM. I never put on a charger unless the battery is disconnected.
Old Dec 22, 2018 | 02:40 PM
redzg's Avatar
redzg
Interesting observation. Any data driving this conclusion? I’m O.K. so far, having charged the battery a considerable number of times, but have only used the one 6 amp charger.
Old Dec 22, 2018 | 03:24 PM
UM Rebel's Avatar
UM Rebel
Yes, I have replaced 2 EBCMs. Each one failed after recharging battery.. I know, I'm a slow learner. Thank goodness first one was under warranty
Old Dec 22, 2018 | 07:23 PM
rickw99vette
Are you referring to a battery trickle charger? Or a regular battery charger ? Trying to find anything that will help prolong the life of the ECBM. Thanks !
Old Dec 22, 2018 | 08:48 PM
STRMLNE's Avatar
STRMLNE
I’ve never seen anything about the battery charging issue. Interesting. I’ve heard once it’s repaired by abs fixer there aren’t any issues.
Old Dec 23, 2018 | 12:31 PM
awches's Avatar
awches
Been leaving Battery Tender Plus on my batteries for years when vehicle is not in use with no problems. But, I think it's only rated at about 2 amps.
To Ecbm
