Drivers side window switch swap????
Old Dec 29, 2018 | 08:56 AM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
Default Drivers side window switch swap????
Can you replace a non memory package window switch with a memory package switch? The connector looks the same. The memory package switches are cheaper and more available it seems.
Old Dec 29, 2018 | 01:47 PM
SilverC54me's Avatar
SilverC54me
I believe that they are compatible. If I recall correctly, the additional wires that would connect the memory related buttons are not in the door harness to the door control module.
Gary
Old Dec 29, 2018 | 04:12 PM
burbleflyer
St. Jude Donor '08
Gary
Thanks. I thought they might be.
Old Feb 8, 2019 | 01:51 PM
CrossedPistols's Avatar
CrossedPistols
Did you get it? Did it work? I need a new driver's side power window switch for my C5 and you are right, the version with the seat memory settings is far less expensive than the one without.
Old Feb 8, 2019 | 05:12 PM
DaveC-98-C5's Avatar
DaveC-98-C5
I swapped the switch out back in November. Memory for non memory controller. Only problem I have now is that the car has a habit of moving seats and mirrors to the saved positions for setting 1&2. In other words I installed the memory switch and got memory features..
To Drivers side window switch swap????
