Rear End Squeak
Old Dec 31, 2018 | 02:44 PM
RPGR90s's Avatar
RPGR90s
Default Rear End Squeak
New to me 2000 Convertible with 53k.
I notice a very slight squeaking from the rear end while driving, if the suspension is working.
Further confirmation of the same noise in the garage if I push down to compress the suspension.
Any idea what it could be?
Thanks,
RPGR90s
Old Dec 31, 2018 | 02:46 PM
foggy's Avatar
foggy
Shocks and/or Sway Bar Endlinks
Old Dec 31, 2018 | 07:02 PM
UM Rebel's Avatar
UM Rebel
Also may be upper control arm bushings. Spay some oil on the bushings and see if squeak goes away.. That's not a fix. If the squeak goes away, you need to replace the bushings. I've never done it but looks like a fairly easy job.
Old Dec 31, 2018 | 08:57 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
I did my end links a couple of weeks ago. It took about an hour to do all four. My bushings were find with 49k on the car.
Old Jan 2, 2019 | 08:31 AM
RPGR90s's Avatar
RPGR90s
Thank You everyone for your replies. I'll crawl under there this weekend and have do some further diagnosis.
RPGR90s
Old Jan 2, 2019 | 11:04 AM
knewblewkorvette's Avatar
knewblewkorvette
Thanks,
RPGR90s
When my 98 did that, it was the bushings.
Old Jan 3, 2019 | 01:25 PM
wcsinx's Avatar
wcsinx
Good suggestions so far, but I'll add that when I had a rear squeak whenever the suspension traveled, it turned out to be the exhaust hanger. (the one right behind the bumper) The rubber pad had worn off, and it was going metal to metal.
Old Jan 3, 2019 | 03:13 PM
RPGR90s's Avatar
RPGR90s
I appreciate that. I'll take a very close look.
Old Feb 3, 2019 | 11:13 AM
thevelvetglove's Avatar
thevelvetglove
Default Squeak
I have have the hanger squeak. There are two springs that attach to the mid section of the exhaust whic now squeak. I tried spraying silicone spray on the springs and that lasted about 5 minutes. Any ldeas?
Old Feb 3, 2019 | 04:23 PM
Fast one's Avatar
Fast one
Coat the springs with antseize.
To Rear End Squeak
